Plaats een nieuw onderwerp Antwoord op onderwerp  [ 67 berichten ]  Ga naar pagina 1, 2, 3, 4, 5  Volgende
BerichtGeplaatst: di jan 25, 2011 20:25
Woonplaats: Brabant
Hoi,
Je kan inderdaad makkelijk builsheet opvragen bij chrysler, die van mij bevat:
Mij viel de volgende zaken op, is dit positief? is gekleurd:
*M9 Cloth 40/20/40 Prem Bench Seat
-D5 Med Slate Gray
AFZ Quad Cab Big Horn Value Group
AHC Trailer Tow Group
APAS Monotone Paint
A55P 5.7L Eng(EZB)/5Spd A/T 545RFE(DGQ)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
CVN Folding Flat Load Floor Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DMHP 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAGC All Gas Engine
EZB 5.7L V8 HEMI MDS Engine
GACS Tinted Glass Windows
GFDP Rear Sliding Window
GNK Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry is dit afstandbediening?? echter zou niet weten hoe het werkt.
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
K4XP STRIPE/BADGE/MOLDING/COLOR
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MF1P Bright/Bright Grille
MGAS Ram's Head Badge
MTDS SLT Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
MYFP Bighorn Badge
NAS 50 State Emissions
NBEP U.S. Emissions w/OBD 1
NBKP EVAP Control System
NFU 34 Gallon Fuel Tank
NHDP Heavy Duty Transmission Oil Cooler heb ik nu ook het P probleem nog?
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PX8A Black Clear Coat
QX8S Black Clear Coat
RAAC All Radio Equipped Vehicles
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
RSAP Sirius Satellite Radio
SBAS Power Rack and Pinion Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTJP P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WGAP 20" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WPAP 20" Aluminum Wheels
XA8S Non Adjustable Pedals
XBSS Pickup Box
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XZ9A Assembly Plant Part Tracking
X81S Instrument Panel Parts Module
X88S Tire & Wheel Parts Module
X95P Call SIRIUS to Activate@888-539-7474
X97P 1-Year Service Provided by SIRIUS
YAA Build To U.S. Mkt. Specifications
YGPA 2.5 Additional Gallons of Gas
ZASP Spring - Left Rear
ZJBP Spring - Left Front
ZNSP Spring - Right Rear
ZXAP Spring - Right Front
Z1GS GVW Payload Rating
0FAA FAM: JR TRACKING: 50926S22 MY:2006
0FEA FAM: DR TRACKING: 50810T17 MY:2006
0FMA FAM: DR TRACKING: 50909T06 MY:2006
1AAS U.S. Dealer Retail
166S Zone 66-Orlando
2TGA Customer Preferred Package 2TG
26G Customer Preferred Package 26G
3VTA Customer Preferred Discount
3XVA Big Horn Regional Package Discount
4VL ISVL Tracking
42CP Warren Truck Assembly Plant
5I2S Two Wheel Drive (2WD)/(4X2)
5NN Reassignment Waiver
5ZBS Price Class H
5ZES 6 FT. Cargo Box
5ZKS Quad Cab
5ZLS 1500 Series
5ZWS DR-Vehicle Family
594S Vehicle Order Tracking
6F2 Paint Order Code
6USS U.S. Specifications Label
610S Florida Ship to State Code
910S Florida Sold to State Code
Grtz,
Elmo
BerichtGeplaatst: di jan 25, 2011 20:28
dit betekent als het goed is dat zonder de sleutels in je deur te doen er toch in kan komen
door de zender in je sleutel en ontvanger in je auto
dus als het goed is en je bent in de buurt van je auto met je sleutels kan je gewoon de deur los doen
(zo werkt het bij de :( Renault Megane :( van men vader)
smaak zit gelukkig niet in de genen :P
Jesse
BerichtGeplaatst: di jan 25, 2011 20:33
Woonplaats: Doetinchem
GXMS Remote Keyless Entry is idd je centrale deurvergrendeling in/aan de sleutel
Egon
BerichtGeplaatst: di jan 25, 2011 21:18
Is de fabriek waar de truck is geasembleerd, heb ik net ontdekt via deze topic :D
viewtopic.php?f=4&t=9600
BerichtGeplaatst: di jan 25, 2011 22:17
Woonplaats: Brabant
Op verzoek de aanvraag URL
http://www.chrysler.com/webselfservice/ ... /index.jsp
Dan selecteer je Customer Assistance
en dan send us a Email
gewoon je details invullen en vertellen dat het een geweldige auto is en dat je graag de buildsheet wil hebben om je documentatie compleet te maken :mrgreen:
Grtz,
Elmo
Laatst bijgewerkt door elmo op di jan 25, 2011 23:37, in totaal 3 keer bewerkt.
BerichtGeplaatst: di jan 25, 2011 23:31
Hey Elmo, wat heb jij ingevuld als zip code want die neemt hij niet aan van mijn dorpje uit Belgie :roll:
BerichtGeplaatst: di jan 25, 2011 23:37
Woonplaats: Brabant
:oops: verkeerde URL doorgegeven ik heb het aangepast....
Grtz,
Elmo
BerichtGeplaatst: di jan 25, 2011 23:41
a ok en wat moet je dan kiezen om aan te vragen?
I would like NEW VEHICLE information.
Am I eligible for SPECIAL OFFERS?
I have a FINANCE/LEASE question.
I need information about EXTENDED SERVICE COVERAGE.
I have a question about 24-HOUR TOWING ASSISTANCE.
I need RECALL OR CUSTOMER SATISFACTION NOTIFICATION INFORMATION.
I'm looking for OWNER'S MANUALS OR SERVICE PUBLICATIONS.
I have an OWNER AND / OR ADDRESS CHANGE.
I need CUSTOMER ASSISTANCE.
I'm interested in CAREER OPPORTUNITIES.
BerichtGeplaatst: di jan 25, 2011 23:54
Woonplaats: Brabant
en dan Send Us a Email houd je vin paraat.
Grtz,
Elmo
BerichtGeplaatst: di jan 25, 2011 23:58
ok dat had ik al gevonden ondertussen maar daar moet je ook terug een zip code ingeven :?:
BerichtGeplaatst: di jan 25, 2011 23:59
Wil ook maar niet lukken bij mij :?
BerichtGeplaatst: wo jan 26, 2011 0:04
Woonplaats: Brabant
Andere mogelijkheid is:
ga naar:
http://www.chrysler.com/en/
dan click je op:
Onder aan in de balk op CONTACT US
Dan:
Dan op:
Send us an Email
Dan krijg je deze tekst te zien andere opmaak(layout):
Is this a question regarding your Vehicle? Yes No
(If 'Yes', please fill out the Vehicle Information section)
Vehicle Information:
Please provide the last 8 characters of your VIN (Vehicle Information Number)
VIN: * LAATSTE 8 CIJFERS VAN JE VIN
Current Mileage: METERSTAND
Servicing Dealer/Facility: N/A
Customer Information:
Title:
First Name: * Middle Initial:
Last Name: *
Address 1: *
Address 2:
City: *
State: * AK
Zip Code: * 78484
Depending on your request we may need to contact you.
Telephone: Work Home *
E-mail Address: * Example: johndoe@chrysler.com
Briefly describe:
Please describe in one sentence the reason for contacting us.
(Maximum of 256 characters)
WOULD LIKE TO HAVE THE BUILDSHEET OF MY CAR
Please enter additional information to assist us in responding to your inquiry.
I LIVE IN BELGIUM/THE NETHERLANDS AND I WOULD LIKE TO HAVE THE BUILDSHEET OF MY DODGE RAM .500.
THE CAR HAS BEEN IMPORTED AND I WOULD LIKE TO HAVE TO BUILDSHEET TO COMPLETE MY DOCUMENTATION.
OF IETS ANDERS.....
* Required field
Grtz,
Elmo
Laatst bijgewerkt door elmo op wo jan 26, 2011 0:09, in totaal 2 keer bewerkt.
BerichtGeplaatst: wo jan 26, 2011 0:09
en wat voer je in als state en zip ?
BerichtGeplaatst: wo jan 26, 2011 0:11
Woonplaats: Brabant
zie boven je vraag, gewoon wat invullen zat volgens mij geen check op.
leg je later uit in de additional information
Grtz,
Elmo
BerichtGeplaatst: wo jan 26, 2011 0:13
Volgende poging dan maar :D
