Het is nu wo sep 16, 2026 17:18
Plaats een nieuw onderwerp Antwoord op onderwerp  [ 67 berichten ]  Ga naar pagina Vorige  1, 2, 3, 4, 5  Volgende
BerichtGeplaatst: zo jan 30, 2011 0:59
Zal mijne buildsheet er dan ook maar 'ns opzetten hé :D
*V9 Cloth 40/20/40 Bench Seat
-DV Dark Slate Gray
APAS Monotone Paint
A82P 4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
BAZS 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CFMP Rear Folding Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLAS Front Floor Mats
CSPS Passenger Assist Handle
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHES Man Shift-on-the-Fly Transfer Case
DJMS 205MM HD Front Axle
DMH 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EAGC All Gas Engine
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
I87S Route 87 - UP, San Antonio, TX
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MGAS Ram's Head Badge
MTDS SLT Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
NAS 50 State Emissions
NBKP EVAP Control System
NB6P Federal Tier 2, Bin 10C Emissions
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NZDP Next Generation Engine Controller
PDMA Mineral Gray Met. Clear Coat
QDMS Mineral Gray Met. Clear Coat
RAAC All Radio Equipped Vehicles
RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTY P265/70R17 OWL All Season Tires
TZAP Goodyear Brand Tires
WF1S 17" Steel Spare Wheel
WF4 17X8.0 Alum Machined Cast Wheels
WLZC All Aluminum Wheels
WMJP Center Hub
XA8S Non Adjustable Pedals
XBSS Pickup Box
XFUS Trailer Tow w/4-Pin Connector Wiring
YAAS Build To U.S. Mkt. Specifications
YGPA 2.5 Additional Gallons of Gas
ZBSP Spring - Left Rear
ZCFP Spring - Left Front
ZPSP Spring - Right Rear
ZREP Spring - Right Front
Z6CS GVW/Payload Rating
1AAS U.S. Dealer Retail
163S Zone 63-Dallas
2TGA Customer Preferred Package 2TG
24G Customer Preferred Package 24G
4KZP 4X4 Tracking
5I4S Four Wheel Drive (4WD)/(4X4)
5ZES 6 FT. Cargo Box
5ZKS Quad Cab
5ZLS 1500 Series
5ZWS DR-Vehicle Family
594S Vehicle Order Tracking
6FE Paint Order Code
6USS U.S. Specifications Label
644S Texas Ship to State Code
944S Texas Sold to State Code
BerichtGeplaatst: wo feb 02, 2011 13:31
vandaag ook aangekomen die van mij, is dezelfde wat ik van de dealer had gekregen.
THE BUILDSHEET
Thank you for contacting the Chrysler Customer Assistance Center.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code: --- Description:
*GJ Leather Trimmed Bucket Seats
-DV Dark Slate Gray
ADB Protection Group
APA Monotone Paint
BABS 160 Amp Alternator
BC6S 625 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CACP Low Back Bucket Seats
CAJP Ventilated Front Seats
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags**
CJ2P Supp. Side Curtain Frt/Rr Air Bags
CLEP Front & Rear Floor Mats
CMAP Heated Front Seats
CSXP Rear 60/40 Split Folding Seat
CTMS Deluxe Door Trim Panel
CV2S O/Head Console w/Trip Computer/UGDO
CV3P Urethane Shift Knob
DHSP Floor Mount Automatic Shift Lever
DH8P Elec Shift On Demand Transfer Case
DSAP Anti-Spin Differential Rear Axle
DS7S Conventional Differential Frt Axle
EZH 5.7L V8 HEMI MDS VVT Engine
GFES Rear Power Sliding Window
GNCS Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GU4S Power Multi-Function F/Away Mirrors
GXXS Sentry Key Theft Deterrent System
HAFS Air Cond ATC w/Dual Zone Control
JATS Instrument Cluster w/Display Screen
JBBS Instrument Panel Woodgrain Bezel
JDCS 200 KPH Primary Speedometer
JFJS Temperature & Compass Gauge
JKVP 115V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPWP Power Lumbar Adjust
JPZP Heated Second Row Seats
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRFP Pwr 10-Way Mem Drvr 6-Way Pass Seats
LABS Tire Pressure Monitoring Warning LP
LAZS Vehicle Information Center
LBCS Glove Box Lamp
LBDS Ash Tray Lamp
LDAS Underhood Lamp
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LEMP Exterior Mirrors w/Memory
LENP Chrome Exterior Mirrors
LETS Traveler/Mini Trip Computer
LEVS Radio/Drv Seat/Mirrors/Pedals Memory
LHES Rear Dome w/On/Off Switch Lamp
LMES Halogen Quad Headlamps
LMGS Automatic Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
LSAS Security Alarm
MENS Front Wheel Spats
MF1S Bright/Bright Grille
MHLS MOPAR Rear Wheel Well Liners
MNES Body Color/Chrome Door Handles
MPPP Rear Wheel Spats
MP8P Delete Black-Out Tape
MS2S Ram 1500 Badge
MTES Laramie Badge
MUSS 4X4 Badge
MW5P Hemi Badge
NA1S Export Emissions
NERP Dual Rear Exhaust
NHDP Heavy Duty Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NHNP Electronically Controlled Throttle
NHSP Heated Steering Wheel
NMCP Heavy Duty Engine Cooling
NMSP Severe Duty Engine Cooling
PXR Brilliant Black Crystal Pearl Coat
QXRS Brilliant Black Crystal Pearl Coat
RC3S 9 Amplified Speakers w/Subwoofer
RDZP Steering Wheel Mounted Audio Ctrls
REZS Media Center 435 CD/DVD/HDD
RSQP Uconnect Voice Command w/Bluetooth
SCVS Leather Wrapped Steering Wheel
SHFS Rear Stabilizer Bar
TW6P P275/60R20 OWL All Season Tires
WGAP 20" Steel Spare Wheel
WMJP Center Hub
WPG 20X9.0 Aluminum Chrome Clad Wheels
XAAP ParkSense Rear Park Assist System
XAMS Power Adjustable Pedals w/Memory
XBNP Tip Start
XBSS Pickup Box
XEAP Tow Hooks
XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate
XFKS 7 Pin Wiring Harness
XGDS Universal Garage Door Opener
XJCP Locking Lug Nuts
XJJS Locking Tailgate
XKAS Export Label
XL3P Russian Language
XME Under Rail Box Bedliner
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X88S Tire & Wheel Parts Module
YABS Build To Export Mkt. Specifications
ZDTP Spring - Left Rear
ZECP Spring - Left Front
ZPTP Spring - Right Rear
ZTCP Spring - Right Front
Z6DS GVW/Payload Rating
1AYS Export Non-Homologated
106S Zone 06-Export
2THA Customer Preferred Package 2TH
25H Customer Preferred Package 25H
3D2A Intl. Price Protection B
3HGA Coso Wt. & D.M.
3HQA Market Homologation
3HWA Export Ocean Freight
3HZA Export Insurance
4ALA 1NTL 37 DAY SCHEDULE
4HA Special Scheduling Condition I
4HC Special Scheduling Condition III
4KZP 4X4 Tracking
4YBA Export Option Requirements
42DP St. Louis Assembly Plant North
5AXS Crew Cab
5A6P Waterbase Paint
5BAS DS/6322 Vehicle Family
5P6 Distribution Services Tracking
5RHS 2009 Vehicle Specifications
5ZCS Price Class P
5ZGS 5 FT. Cargo Box
5ZLS 1500 Series
6EXS Export Specifications Label
8EDA Miscellaneous Intl Dealers
8G6 Kazakstan Country Code
882P Central/Eastern Europe Region Group
895A European Region
Thanks again for your email.
Sincerely,
Tony
Customer Service Representative
BerichtGeplaatst: wo feb 02, 2011 23:18
Jij hebt ook een Kombat truck Sjeng (language Russian) :D :D
BerichtGeplaatst: vr feb 04, 2011 12:34
Is eigelijk bestemd voor de kazakstaanstjes, maar die zijn beter af op een ezel :D :D :lol:
BerichtGeplaatst: vr feb 04, 2011 18:12
hehe klopt en die kunnen ze nog is langs achter nemen ook :D
BerichtGeplaatst: vr feb 04, 2011 19:27
Ik denk ook dat dat gebeurt :D
BerichtGeplaatst: vr feb 04, 2011 21:18
mijn gegevens ook gekregen .....weet eigenlijk niet waarom ik ze opvroeg ....versta er toch geen bal van :mrgreen:
BerichtGeplaatst: vr feb 04, 2011 22:02
heb je pratende gegevens dan :D :D :D :D
BerichtGeplaatst: vr feb 18, 2011 21:30
:D Ik heb 'm ook gekregen :P
Zien jullie hier iets opmerkelijks tussen???(denk zelf van niet veel 8) )
Laat maar horen!!!!!!!!!!!!!!!!!!!
-DV Dark Slate Gray
ADA Light Group
APAS Monotone Paint
DMDS 3.55 Rear Axle Ratio
EAGC All Gas Engine
GNCP Sun Visors w/Illum Vanity Mirrors
I89S Route 89 - CSX, Selkirk, NY
JJAS Cigar Lighter
JPBS Power Locks
LBCS Glove Box Lamp
LBDP Ash Tray Lamp
LCLP Front Dome w/On/Off Switch Lamp
LDAP Underhood Lamp
LNJ Fog Lamps
LPES Cargo Lamp
MFDS Bright Grille
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MXBS Front Air Dam
NBEP U.S. Emissions w/OBD 1
NHMS Speed Control
PBTA Patriot Blue Pearl Coat
QBTS Patriot Blue Pearl Coat
RCDS 4 Speakers
TSRS P245/70R17 BSW All Season Tires
TZHP Michelin Brand Tires
WF2S 17X8.0 Steel Chrome Clad Wheels
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
YEP Manuf Statement of Origin
YGAA Without Billable Fuel
132S Zone 32-New York
3VTA Customer Preferred Discount
4KZP 4X4 Tracking
4SPA Mobility Conversion Tracking
5ZKS Quad Cab
5ZLS 1500 Series
6FC Paint Order Code
633S New York Ship to State Code
933S New York Sold to State Code
Sincerely,
Teresa
...Robert.....
BerichtGeplaatst: vr feb 18, 2011 23:07
@ rowo: op jouw buildsheet staat er dat jij 3.55 rear axle ratio hebt en ik 3.92 rear axle ratio heb. Heb jij een Tow/Haul knop op je shifter zitten ?
BerichtGeplaatst: za feb 19, 2011 23:31
Ja klopt, heb ik er op. Jij niet dan???
Weet jij wat het verschil percies inhoud misschien??
...Robert.....
BerichtGeplaatst: za feb 19, 2011 23:41
Ik heb hier het topic gevonden waarin het verschil word uitgelegd tss de 2
viewtopic.php?f=17&t=3761&hilit=3.55+rear+axle+ratio
maar omdat we een gelijkaardige truck hebben, zit ik te denken dat een 3.92 achteras mss een optie is :dontknow:
BerichtGeplaatst: za feb 19, 2011 23:48
Zou zomaar kunnen, ik weet het eigenlijk ook niet.
Maar heb jij er dan een langere overbrenging op of een kortere?
Dus maakt jou motor meer omwentelingen bij een bepaalde snelheid of minder?
maar heb jij nou ook een tow/haul knop?
...Robert.....
BerichtGeplaatst: za feb 19, 2011 23:57
@ rowo: wat ik eruit begrepen heb is dat bij een 3.92 de motor meer toeren maakt ----> dus meer torque heeft en dus zwaardere lasten zou kunnen trekken met als gevolg een hoger verbruik ten opzichte van een 3.55
Ja ik heb ook zo'n knop op m'n shifter :)
BerichtGeplaatst: zo feb 20, 2011 0:05
Ja ik snap 'm. Ik heb ook net even de link die je eerder gaf bekeken. Thanks het is me nu helemaal duidelijk.
Nog een andere vraag: Heb jij stoffen bekleding? (dacht het uit de buildsheet's van ons beiden te begrijpen) , dan hebben ze bij mij er later leer in gezet.
Het leer ziet er nog zo nieuw uit bij mij dus vandaar dat ik dat denk.
...Robert.....
