Het is nu di okt 20, 2026 0:33
BerichtGeplaatst: di jan 04, 2011 21:03
Geregistreerd: za aug 29, 2009 18:09
Woonplaats: ********** vlaams brabant
Eeps... toch wat tijd gevonden om te posten :)
Twee tal weken geleden effe nagekeken of ik nog geen recalls had voor onze RAM.
En yep... ik heb 2 recalls.Gewoon naar een dodge dealer gaan? of?
Recall 1
We are recommending the following improvements be
performed on some 2009 and 2010 model year Ram trucks.
Recommended Service:
The Heating, Ventilation, and Air Conditioning (HVAC) actuator gears on
your vehicle (VIN: xxxxxxxxxxxxxxxxx) may break and result in the inability to
fully control the HVAC functions.
What your dealer will do:
Chrysler will service your vehicle free of charge (parts and labor). To do this,
your dealer will update the HVAC control head software and test all of the HVAC
mode door actuators. The software update will take about 1/2 hour to complete. If
there are mode door actuators that need replacing, up to 4 additional hours may be
required. We recommend that you make an appointment with your dealer to
minimize your inconvenience.
What you should do:
Simply contact your Chrysler, Jeep, or Dodge dealer, at your convenience, to
schedule a service appointment. Your dealer will collect the necessary information
to ensure that the appropriate parts are available so your service can be completed in
a timely manner. Although not required, we recommend bringing this letter with
you to your dealer, when you bring your vehicle in for this service.
Recall 2
We are recommending the following improvements be performed on some 2009
model year Ram trucks equipped with perforated leather trimmed bucket seats.
The front driver and passenger seat cushion covers on your vehicle
(VIN: xxxxxxxxxxxxxxxxx) may tear during normal usage.
your dealer will replace both the driver and passenger seat cushions. The work will
take about 2 hours to complete. We recommend that you make an appointment with
your dealer to minimize your inconvenience.
What you should do:
BerichtGeplaatst: wo jan 05, 2011 17:00
Deze twee recalls zijn er bij mij gedaan, nieuwe leren bekleding van de voor stoelen en daarna een hele reeks update`s waren er. even bij de dealer langs en kosteloos laten doen.
Als je een tuning van diablo of superschip erop hebt even de originele fabrieks soffware er weer op zetten voordat je naar de dealer gaat :wink:
BerichtGeplaatst: do jan 06, 2011 15:45
THX voor de INFO Sjeng.
I.V.M tuning ...een diabla of supership heb ik nog niet :wink:
Voor de 2de verjaardag van onze RAM zou ik hem een
Trinity T-1000 willen kopen :twisted:
BerichtGeplaatst: do jan 06, 2011 16:14
Ik ben tevreden over de Diablo Sport Predator U7137,
Ik had vandeweek mijn dealer aan de telefoon en hij vroeg voor een klant welke tuning ik erop had,
dus ook voor de begrenzer eraf te halen hij zou ook een diablo predator bestellen voor de klant :wink:
BerichtGeplaatst: di jan 25, 2011 18:03
Als je deze recall hebt vb voor de lederen hoezen.
Worden deze nagekeken en als het nodig is vervangen ze de hoezen.
Of worden deze altijd vervangen?
Volgens de dodge garage waar ik ben geweest was alles ok.
Hij moest enkel de naden checken.
En omdat deze ok zijn heb ik geen recht op de nieuwe hoezen.
BerichtGeplaatst: di jan 25, 2011 19:18
Ik heb de hoezen mooi laten vervangen rij weinig met de dodge.
Bij iemand met normaal gebruik van ongeveer 20.000 km perjaar daar doe ik een jaar of 3 over,
en dan is er geen garantie meer op dus hij had ze al besteld dus moest hij ze er ook opzetten. :lol:
BerichtGeplaatst: za jan 29, 2011 23:50
Aan mijn bekleding was ook niets te zien en toch vervangen ( tis te zeggen,bestuurderskant is al gedaan, moet nog een afspraak maken voor de passagierskant, deze hadden ze niet besteld en bleek na demontage dat deze ook moest vervangen worden nadat ze de nrs gecheckt hadden)
Ben in Strombeek geweest, een zekere Danny houdt er zich daar mee bezig, vriendelijke gast) Waar ben jij geweest?
BerichtGeplaatst: zo jan 30, 2011 11:11
Geregistreerd: wo dec 22, 2010 20:53
Woonplaats: pulle (zandhoven)
bij mij hebben ze dat ook nagezien en alles was in orde.
Maar ze mogen van mij er ook wel nieuwe in steken.
BerichtGeplaatst: zo jan 30, 2011 12:38
Gewoon terug gaan en nieuwe erin laten zetten Gerry :wink:
BerichtGeplaatst: di maart 01, 2011 0:56
Woonplaats: Ulft
Damn dat is een goede ik heb al 70K met mijn Dodge gereden en is wel zichtbaar dat er op gezeten is zeg maar dus geen overbodige luxe. Op welke naden moet je letten dan? Laten die los of .........
http://www.carlectra.nl
BerichtGeplaatst: di maart 01, 2011 18:55
Woonplaats: Ulft
als ik me goed herinner peter geld het ook niet voor jou. je hebt toch ook geen zoom aan de voorkant van de stoel.... bij ten back weten ze er van ik heb het daar na gevraagd.
Erik
99 GMC Sierra 6"lifted
10 GMC Sierra
UCTP.NL
BerichtGeplaatst: vr maart 04, 2011 1:09
Woonplaats: Ulft
Hoe zit die zoom dan Erik?
BerichtGeplaatst: vr maart 04, 2011 8:33
Woonplaats: Ulft
als ik je zie dan stop dan even kan ik het je zo even laten zien. 8)
Erik
10 GMC Sierra
UCTP.NL
BerichtGeplaatst: vr maart 04, 2011 12:45
Ik heb niks laten nakijken ben naar de dealer gegaan de recal laten zien
en gezegt bestellen die zitbekleding.
Toen de materialen binnen waren hebben ze mij gebeld en erop gezet.
BerichtGeplaatst: za maart 12, 2011 18:25
Ik weet niet dat jullie er iets aan hebben maar bij het rondneuzen van info omtrent mijn zoon zijn SRT-8 kwam ik dit tegen.
Safety Recall J37: Brake Pedal Linkage Clip
Date: 01/2010
Potential number of vehicles affected: 20,000 (Grand Cherokee/Commander/Nitro/Liberty/Ram/Sebring/Avenger)
Model year(s): 2010 Grand Cherokee and Commander models built from November 5, 2009 through November 12, 2009
Owner notification start date: January 2010
Defect: The brake pedal linkage clip on about 20,000 of the above vehicles, excluding Dodge Ram trucks, may have been manufactured incorrectly. While some Dodge Ram trucks may not have the clip installed. A defective or missing brake pedal linkage clip could allow the brake booster input rod to detach from the brake pedal which will result in a loss of the vehicle’s service brakes and could cause a crash without warning.
Solution: The brake pedal linkage clip must be replaced on all vehicles.
http://www.wkjeeps.com/recalls/recall_J37.pdf
