Het is nu di okt 20, 2026 17:43
BerichtGeplaatst: ma jan 28, 2013 18:45
Woonplaats: schipluiden
heb 3 keer kontakt aangezet
er kwam een fout melding van
p0601
weet iemand wat dit betekend ?
alles werkt gewoon :!:
wees wie je bent
dat is alles !
gr erwin
dodge ram 1500 4.7 2002
BerichtGeplaatst: ma jan 28, 2013 19:08
p0601
P0601 Control Module Read Only Memory(ROM)
BerichtGeplaatst: ma jan 28, 2013 19:17
Effe gegoogled:
Citaat:
P0601 OBD-II Trouble Code
Technical Description
Internal Control Module Memory Check Sum Error
What does that mean?
Basically that means that there is an interal fault in the Powertrain Control Module (PCM). There have been many reported PCM failures on Chrysler/Dodge products although it is possible for this to happen on any vehicle. In Dodge/Chrysler products, a P0601 trouble code means that a serial communication failed inside the computer at least 6 times.
Symptoms
Likely, no symptoms will be discernible to the driver, other than the illuminated Check Engine Light. Typically the engine runs fine, gauges work, etc.
Causes
A code P0601 in most cases means the PCM has gone bad. This is possibly due to a short-circuit inside the PCM. Or, if you disconnect the wires/connector from the PCM while the battery is still connected, that may also cause this code.
Possible Solutions
With a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed (we recommend you take it to a dealership for this). The good news is it *may* be covered under your emmissions warranty. So even if you're out of bumper-to-bumper warranty or powertrain warranty, check your warranty guide or dealer to see if this is covered.
Other people have reported that they cleared the code only for it to return again and again. Keep in mind that most shops can replace the PCM but not all can program it.
BerichtGeplaatst: ma jan 28, 2013 19:29
Belgiquebasterd schreef:
Effe gegoogled:
Citaat:
Symptoms
Causes
Possible Solutions
oke'
en nu het NL
mijn techniche engels is niet zo :!: :D
wees wie je bent
dat is alles !
gr erwin
BerichtGeplaatst: ma jan 28, 2013 19:44
Effe gegoogled:
Citaat:
Symptoms
Causes
Possible Solutions
oke'
en nu het NL
Meneer is niet gauw tevreden :D
Techische beschrijving
Betekent dat er een interne fout is in de PCM (motorcomputer). Er zijn vele problemen met PCM's gemeld bij Chrysler/dodge produkten, alhoewel het bij ieder voertuig voorkomt. Bij chrysler/dodge producten betekent een P0601 code dat er 6x een communicatiefout is gemeld in de computer.
Symptomen:
Meestal zijn er geen symptomen merkbaar, behalve het 'check engine light'. Meestal loopt de motor goed, meters werken,...
Oorzaak:
Een P0601 betekend in de meeste gevallen dat de PCM slecht is. Dit is mogelijk door een kortsluiting binnenin de pcm. Deze code kan ook echter het gevolg zijn wanneer je draden/connecters verwijderd van de PCM zonder eerst de batterij af te koppelen.
Mogelijke oplossingen:
Bij een P0601 code is de meest voorkomende oplossing het vervangen en herprogrammeren van de PCM. In sommige gevallen kan de dealer de PCM reflashen (herprogrammeren) en het oplossen. Maar meer dan waarschijnlijk moet de PCM vervangen en geherprogrammeerd worden.
Zo dat is het belangrijkste vertaald, faktuur volgt :D
BerichtGeplaatst: ma jan 28, 2013 19:56
Effe gegoogled:
Citaat:
Symptoms
Causes
Possible Solutions
oke'
en nu het NL
Symptomen:
Oorzaak:
oke'
nu is het duidelijker :D
maar nu is mijn vraag kan dit erg kwaad om door te rijden
of moet het opgelost worden
ik rij er mischien al te lang mee rond :!:
:D :D :D stuur de rekening maar door :D :D
wees wie je bent
dat is alles !
gr erwin
BerichtGeplaatst: ma jan 28, 2013 20:08
Enige 'gevaar' wat ik kan zien is dat er ergens een ander probleem komt waardoor je 'check engine light' gaat branden maar dat je dit niet opmerkt omdat het zowiezo al aan het branden is door dit probleem. Wanneer je check engine light al brand en je krijgt nog een probleem dan begint het te knipperen om aan te geven dat er een nieuwe fout is, dit kun je makkelijk missen, zeker op een zonnige dag.
Ik weet niet welk bouwjaar je hebt maar vanaf 2004 zijn de pcm's gekoppeld aan je vin nummer, dus je kunt niet zomaar een nieuwe pcm monteren, je moet een nieuwe pcm monteren en die dan door een dealer laten programmeren/koppelen aan je vin nummer anders doet hij het niet. Een 2003 kun je wel gewoon een andere pcm erin bouten en rijden.
BerichtGeplaatst: ma jan 28, 2013 20:54
Woonplaats: Schiedam (JEROEN)
Controleer eerst de stekkers op de pcm op corrosie.
En de stekkers aan de onderzijde van je relaiskast.
Daarna de achteraf tussen gesoldeerde lpg bedrading. Best kans dat er een draad is door gecorrodeerd door solderen met s39... :roll:
Heb zelfs al lpg installs gezien met scotch blocks... :banghead:
En dan kan je altijd nog een pcm uitwisselen met iemand die ook een 2003 heeft..
Gebruikte pcm modules gaan regelematig voor minder dan $150 dollar op ebay motors. :wink: :wink:
JEROEN...
http://WWW.MOPARTRUCKSHOP.NL
BerichtGeplaatst: ma jan 28, 2013 21:16
hij is van eind 2002
en ik heb geen gas
alleen koken en kamperen doe ik met gas :D :D
wees wie je bent
dat is alles !
gr erwin
BerichtGeplaatst: ma jan 28, 2013 21:18
en ik heb geen gas
Kan je alvast 1 optie uitsluiten.. :D
Is het dan een 5.9 of toch een Hemi? :roll:
JEROEN...
BerichtGeplaatst: ma jan 28, 2013 21:20
HollandBlower schreef:
en ik heb geen gas
geen van twee
een 4.7
wees wie je bent
dat is alles !
gr erwin
BerichtGeplaatst: di jan 29, 2013 21:30
heb vanmiddag effe de klep open getrokken en de accu losgekoppelt
en aan alle stekkers gezeten los en vast gemaakt er was geen verandering
de fout code was nog het zelfde denk toch dat de pcm geherprogrameerd moet worden of vervangen :(
als iemand er een in de aanbieding heeft hoor ik het wel :D
iniedergeval bedank voor de informatie :)
wees wie je bent
dat is alles !
gr erwin
