Het is nu zo sep 20, 2026 18:43
 Berichttitel: Aeroforce
BerichtGeplaatst: za dec 27, 2008 0:55
Woonplaats: Bergen op Zoom
Hey gasten,
Lang geleden maar daar ben ik eventjes weer, op het VTCOA willen ze een group buy gaan doen. Iemand heeft de set nu gekocht en gaat hem deze dagen testen. Ik wil ook zo`n setje kopen. Hoe meer mensen deze meters kopen hoe sneller de leveranciers de flash zullen aanpassen voor de SRT-10
Filmpje!! http://videos.streetfire.net/video/Aeroforce-SRT4-gauge-demo_143967.htm
Dit kun je er mee :
1. MPH
2. Intake Air Temperature
3. Engine Coolant Temperature
4. Battery Voltage
5. Long Term Fuel Trim
6. Short Term Fuel Trim
7. O2 Sensor Voltage
8. Manifold Pressure (vacuum/boost) displayed in PSI
9. Ignition Advance
10. Engine run time
11. Fuel Status (open/closed loop)
12. Throttle Position Percentage
13. Engine Load
14. RPM
That's for now...14 out of 36
The Interceptor is capable of displaying the following parameters, two at a time (8 using cyclic scan), at an adjustable rate of up
to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will
display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this
and make it available for display
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 5' cable is included with
appropriate OBD2 connector. A splitter cable is included with the dual Interceptor units.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once
selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle
exceeds 60%. Approximately 60 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored
data on the Interceptor display.
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined
period of time. This way you can monitor several items without taking any other actions.
High intensity LEDs can be used as shift lights or warning lights to indicate when a selected parameter exceeds an entered
threshold. Due to the gauges extremely fast update rate, this light is very accurate and easy to set. Once you try it you'll find you
can't live without it!
Another menu option offers the ability to swap the foreground and backround colors of the display. Using this feature, for example,
the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive
image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in
bright sunlight, negative at night.
The Interceptor's scan rate can also be adjusted through a menu function.
DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.This essential feature will help the gauge to pay
for itself the first time the check engine light comes on. Those that have modified their vehicle will find this very handy when a
sensor, vacuum line, etc. has been inadvertently left disconnected, or something was just not put back together properly. Click
here for a list of SRT-4 diagnostic trouble code descriptions.
The two analog inputs can be configured through menu choices. A linear conversion can be entered so that an analog signal
connected to the gauge can be read in appropriate units. These inputs are handy for pressure signals such as those from MAP
and oil pressure sensors, analog outputs from Air/Fuel ratio kits, etc. These signal can then be read and recorded along side the
other parameters obtained on the vehicle's bus.
The gauge has bi-directional controls allowing for manaul control of the low and high speed fans.
Last but not least, the Interceptor will measure 0-60 times, as well as 1/8 and 1/4 mile time and speeds. This is accomplished
through a simple menu selection.
Installation is accomplished by simply plugging the supplied connector into the OBD2 port below the steering wheel. Literally
plug-and-play!
Warranty
Aeroforce Technology warrants this product and its accessories against defects in material and workmanship for a period of 1 year from
the date of purchase.
5th gen Ram 1500
 Berichttitel: Re: Aeroforce
BerichtGeplaatst: za dec 27, 2008 1:07
koele meters, de SRT display in't begin is een leuk gadget...
Spijtig dat ik dit jaar m'n autometer heb geplaatst...ga passen maar ben curieus naar het eindresultaat.
Go fot it Justin.
Ze waren niet zo duur dacht ik trouwens...
BerichtGeplaatst: za dec 27, 2008 1:19
Ze zijn inderdaad goed te doen, ik zal de thread in de gaten houden! 8) 8)
$399 for the duel gauge. $239.00 for the single.
http://www.aeroforcetech.com
http://www.vtcoa.com/forums/showthread.php?t=29851
5th gen Ram 1500
BerichtGeplaatst: za dec 27, 2008 1:41
Woonplaats: Kempen Belgie
toffe spullen hoor
Groeten Eric
Dodge Ram
Buell X1
BerichtGeplaatst: za dec 27, 2008 10:08
Dat ziet er echt super gaaf uit 8)
