Het is nu za sep 19, 2026 11:33
BerichtGeplaatst: di nov 03, 2015 12:18
Na de verkoop van mijn Avalanche verkoop ik nu mijn Predator.
De predator is ontkoppelt van de Avalanche en zit uiteraard geen VIN lock op.(standaard tune is teruggezet en de unit is ontkoppelt van mijn VIN)
Onderstaand stukje ff gepikt van de site van Diablosports zelf;
Predator Applications
The Predator 1999-2002/3 GM V8 vehicles is applicable for the following vehicles:
1999-2003 Corvette 5.7L LS1
1999-2003 Corvette 5.7L LS6
1999-2002 Camaro 5.7L LS1
1999-2002 Firebird / Trans Am 5.7L LS1
1999-2002 Chevrolet Silverado, Tahoe, Suburban, Avalanche
4.8L, 5.3L, 6L, 8.1L (except 1999 5.7L)
1999-2002 GMC Sierra, Denali, Yukon
2002 Cadillac Escalade
How to verify that the vehicle is supported
The eighth (8th) position in the vehicle identification number (VIN) is the code that designates the engine type. The Predator will support the vehicle if the engine code is:
1999-2000 Car: 8th digit of the VIN= G
2001-2003 Car: 8th digit of the VIN= G or S
1999-2000 Truck or SUV: 8th digit of the VIN= V, T or U
2001 Truck or SUV: 8th digit of the VIN= G, V, T or U
2002 Truck or SUV: 8th digit of the VIN= G, N, V, T, Z or U
What is the GM Predator?
The Predator for 1999-2002/3 GM V8 vehicles (part no. U7198) is a state-of-the art high performance tuning flash programmer, which advances the timing, optimizes the air/fuel ratio and remaps the transmission shift points (in automatic transmissions). Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
Why to get DiabloSport Predator?
The flash tuner that allows for end user adjustability
The flash tuner which accepts custom tunes directly from DiabloSport or from ChipMaster Revolution dealers that you can install yourself
The flash tuner with built-in advanced diagnostic capability that displays fault codes along with descriptions of the code right on the Predator screen
The flash tuner with data monitoring capability
The flash tuner with a true graphical display that's 300% larger then the competition's puny text only display
The flash tuner running on a custom high performance, multi-threading KROS operating system
Dyno Tested Performance Tunes The Predator was created with one thing in mind, POWER!
Performance Tune: Designed to add power and torque using premium fuel.
87 Octane Tune: Designed to add power and torque using low to mid grade fuel.
Factory Tune: Designed for users who wants to adjust parameters using the factory tune.
Average power gains for Performance tune are in the 20-30 RWHP range. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration, firmer shifts, better mileage and improved towing characteristics, whether it is in town or out on the highway towing an 8,000 lbs trailer.
The power increase in the lower RPMs will yield a better throttle response; help maintain speeds on inclines and towing. The wider power band that the Predator creates will be particularly noticeable in city driving, where speeds constantly change. The mid-to-upper power increase is extremely useful on the highway when passing slower vehicles and to quickly maneuver out of emergency situations.
The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
Predator tunes re-map the:
Fuel Curves
Timing Curves
Torque Management
Extend Speed Limiters
Extend Rev Limiters
Disable CAGS (Skip Shift)
Part and Full Throttle Shift Points
Shift Timing
Shift Presure
DiabloSport Performance tunes require the use of Super Unleaded / Premium grade fuel only, like carried by Amoco/BP, Sunoco or Mobil.
Adjustable Parameters
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle. Because it allows for timing and fuel adjustments the end user can optimize the tune for his/hers specific vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predator's live data feature to monitor timing and other vital parameters.
The Predator allows the end user to adjust the following parameters:
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters
Rev Limiters
Part Throttle and WOT Throttle Shift Points
MPH Up and Downshifts
Shift Timing
Part Throttle and WOT Throttle Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
NEW ADDITIONAL ADJUSTABLE PARAMETERS
Torque Management ON/OFF adjustment
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Injector Adjustment
Adjust for different injector size
Adjust for long term fuel trims
Catalytic Overtemp protection Adjustement
Adjust COT enable temperature
Transmission functions do not apply to trucks with the Allison transmission.
Diagnostics and Live Data Monitoring
The Predators diagnostic features allows end user scan and erase fault codes as well as monitor live data while driving. Predator can read and erase fault codes, and contains all the manufacturer specific P codes. Predator diagnostics will work on 2003 H2 Hummer vehicles.
Vin Lock
The 1999-2002/3 Predator for GM revision 2.10 and up will unlock itself from vehicle once original backup is restored so it can be used on another vehicle..
Custom Tuning
Custom Tuning can be done for almost any application without the need for the end user to send the Predator. We have PC Interface kits and software available for download and the tunes can be sent via e-mails or you can go to a localy tuning facility. Many of your custom tuning questions involving DiabloSport products may already be answered in the FAQ section of DiabloSports' website. If not you can post questions and get the answers in 24 hours
My Avy 2002,
Gebruikers op dit forum: Majestic-12 [Bot] en 8 gasten
